Home > Maintenance & Mods (L322) > Illuminated sill plates Repair
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Drivers side sill plate did not light up having looked at the cost of replacing I thought a repair would be worthwhile.
Ordered some 5050 12v strip lights - 30cm long of the internet - £3.99 for 4 blue ones.
Took trim strip off , it is held by 4 clips and can be gently levered upwards to release them. au clipped the feed wire and into the workshop with it. Cut the wires near the black box leaving plenty to reconnect to. Black box and silver light trim pulled off and cleaned up glue residue. I also took out the clear Perspex strip to clean up - this needs to be carefully prised out so you don’t break it, mine was dirty if yours is clean I would leave it in place.
Glued Perspex back in place with contact adhesive.
I attached the led strip to the inside of the aluminium strip opposite the Perspex. I tried attaching the led next to the Perspex but the leds didn’t line up correctly with the lettering. Note the led is polarity sensitive so you need to wire it and make sure it works before final connection to the existing connector off the old light fitting.
Installation requires the plastic pegs to be carefully lined up after reconnecting the lights then pr Bow down sing firmly in place.
Picture was taken in broad daylight and looks good - need darkness tonight for final verdict. Will probably update the passenger side next.
 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #520839 6th Jul 2019 12:19pm
Thumbs Up Thumbs Up Thumbs Up
Post #520911 7th Jul 2019 12:47am
kooky_guy
Can you link to the strip lights you used?
I have a broken pair that I've been trying to repair, but the electroluminescent tape I bought online is useless. Even worse than the original.
I bought a replacement pair, but they're not very bright either, especially with LED puddle lights. 2010 4.4 TDV8 Vogue SE
Post #521034 8th Jul 2019 8:01am
V8 Bob
eBay - 12v 5050 led strip light. I got it off Wow Factor
They come in either 10cm or 30cm length - I used 30cm, and come in various colours white, blue, red, green and warm white - mine are blue.
The 5050 is the led size 5mm x 5mm. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #521054 8th Jul 2019 10:58am
kooky_guy
Thanks V8 Bob. Will have a look. 2010 4.4 TDV8 Vogue SE
Post #521161 9th Jul 2019 9:01am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Changed mine twice the last two fattys and used these cob lights a few years ago https://rover.ebay.com/rover/0/0/0?mpre=ht...2068190047
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #521184 9th Jul 2019 11:42am
RobWheatley
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Where are the sill's available from, been looking around and cant seem to find any for a 2008 l322 2010 L322 3.6 TDV8 Vogue Stornaway Grey
Post #521244 9th Jul 2019 6:23pm
V8 Bob
Can’t find new ones on the net at the moment probably best to contact specialist car breakers 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #521318 10th Jul 2019 9:09am
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
I've had them saved in my ebay list for ages - here you go:
https://www.ebay.co.uk/itm/GENUINE-RANGE-R...2117073573 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #521344 10th Jul 2019 1:47pm
RobWheatley
Thanks SidewaysMatt, listing says for 2010-12, will they fit a 2008 do you know? 2010 L322 3.6 TDV8 Vogue Stornaway Grey
Post #521375 10th Jul 2019 5:34pm
SidewaysMatt
I believe they fit all, obviously if yours didn't have them originally you'll need to source a power feed for them - I believe folks take a feed of the knee level courtesy lights. 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #521566 12th Jul 2019 12:36pm
j9ffy
France 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Thanks for this repair guide - my passenger side EL has failed and I wondered if anyone had been able to source a new EL assembly. I might drop a line to GSM Industrial Graphics as they seem to be the 3rd party supplier, see if they can sell me an EL strip.... you never know!
Cheers,
J.
Post #525964 23rd Aug 2019 8:32pm
j9ffy
FWIW I spoke with GSM today. They were very pleasant and helpful, but they only deal with the car manufacturers directly so can't supply replacement EL units to the "public".
They told me that their EL units are made in-house.
Let the search for a Far East alternative begin Very Happy
Post #526229 27th Aug 2019 12:32pm
Corsica
France 2011 Range Rover HSE TDV8 Santorini Black
Hi
I would like to mount the ignition plates or I can plug in to power them
Post #526279 27th Aug 2019 8:15pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
j9ffy, check these out, read the 1st review... https://www.aliexpress.com/item/3281110183...b201603_52 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #526304 28th Aug 2019 2:58am
