![]() | Home > Technical (L322) > Auto Wipers |
You'd have the same mirror if you had the rain sensor - it's just the cover around the base that's different.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Thanks Steve,
I believe everything else is the same (no guarantees,tho). I don't know how much a sensor is - I'd look at the breakers for a sensor/mirror base cover if it's very expensive new. You'll need to make sure the loom is there or you'll need to add that too (split the base cover and check for a 4(?) pin plug. And you'll need a new mounting pad for the sensor (the purple part that sticks to the screen). If that's not avail at the dealers, I'd check autoglass shops. |
Hackweg Member Since: 06 Oct 2010 Location: Medway Posts: 22 ![]() ![]() ![]() |
I also have a 54 plate Vogue, and both the automatic wipers and automatic lights do not appear to work, see thread http://www.fullfatrr.com/forum/topic4473.html?highlight=automatic .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35783 ![]() ![]() |
its possible that a reboot of all the ecu's is required ..try disconnecting the battery for at least an hour or so and see if that helps... ... - .- -.
Right - It appears I don't have this option on my 54 plate Vogue (even though it should have been standard).
even if you did get the sensor ashley , would you have the wiring there.. ... - .- -.
Well according to Dan it should be standard on a 54 vogue. Ii wonder if a previous had had the wrong screen fitted..??
heated rear seats should be standard on a vogue, there are two buttons for this on the back of the center console.
Don't think heated seats came in till Aug 04 according to the link,
Don't mean to drag up an old thread but...
I'll take a pick when i have a minute. |
Cool - thanks mate - I guess it's root around time to see what I can find. I know there was something like that behind the little mic cover in the console but that may be for .... Well..... the mic I guess!!
hi, its the same as the mic plug...have you taken the roof consul down as you can see far better and then you wont damage the roof lining. its held in place by 2 screw's, unclip the lights/switches and remove and you will see the 2 screws behind,when its out you will find what you are looking for |
