Home > Technical (L322) > Air suspension issue
Suggs
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Hi folks
Went out for a drive yesterday and all seemed normal, turned car off and got a inactive suspension flash up then it disappeared. Started car and no message or gong, raised suspension to off road height, went up but seemed to take ages. Lowed to normal and drove a few miles home, felt like the car was a bit low at the front when driving home went in house then came out an hour later and from passenger side sat on the floor (see picture)
. Started engine and it raised up, i could here the compressor then it stopped, this morning it was still at normal height and this eve still at normal height after not being used all day. Ive now raised it to off road height which seemed to rise at normal speed and its seems to be holding up and not loosing air. I was thinking it would be a case of ordering 2 new front struts but as i said it seems to be holding air now. Any one had the same ?
Post #520884 6th Jul 2019 6:56pm
DrRob
Get codes read for a start Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #520886 6th Jul 2019 7:15pm
Suggs
Thanks i have my normal mechanic popping in next week for a look, just thought it odd that one corner was down then seems ok now so wondered if anyone else had the same
Post #520887 6th Jul 2019 7:25pm
Gsxr1250dave
Mine did that it will be the front air bag get under there with some soapy water in a spray bottle turn the steering on full lock both ways usually show it up
Post #520888 6th Jul 2019 7:59pm
Suggs
thanks will do, i guess it may be pinching the hole in the bag at the moment so temporally stopping the leak
Post #520890 6th Jul 2019 8:07pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Mine was very similar, limped all the way home to Lincolnshire from Belfast, the further I got the worse it was, oddly on the motorway it was fine. It turned out to be front offside airbag was leaking (it had cracked where it rolled over and only leaked in certain positions). I feared the worse, took advice on here and decided to have a go myself. New airbag from Island 4x4 (Brilliant company), jacked the car up wheel off and I couldn't believe how easy it all was. First one took me about 90 minutes, the second one just over an hour. Airbag was £125, piece of cake to do. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #520895 6th Jul 2019 8:47pm
Suggs
sounds same as mine, and yeah ive already been looking on island 4x4, will be ordering 2 front bags once my mechanic pops in next week. Think ill buy the complete struts rather than just the bags
Post #520899 6th Jul 2019 9:58pm
AJGalaxy2012
If the strut is OK the bag is an easy change and the kit is a good quality kit from Island 4x4, its only one nut and a spire washer. BMW i3 Electric Car
Post #520914 7th Jul 2019 5:56am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Definitely sounds like the air bag failure as AJGalaxy2012 said, straight forward job.
As you mentioned easier to replace strut / bag assembly, (Tight hub / strut bolts though). Thumbs Up
Post #520922 7th Jul 2019 10:12am
Suggs
Thanks all
Ill have a better look tomorrow as been working all weekend, ive had it running on the drive with the suspension in all positions and cant get it to loose air again, had it in the off road position all night and normal position all day (engine off) and not dropped at all, compressor not running either. Im guessing the airbag has rolled over the hole so not leaking
Post #521004 7th Jul 2019 7:58pm
Andy2986
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Hiya, have just had a similar thing happen to me on my new ( to me) 2012 4.4 tdv8.
Car was getting called hissing Sid !!!
I replaced both front airbags with Arnott ones. ( I did look at island 4x4 ) but the arnott ones were only a little bit more.
I found it an easy job. I put a whole day aside and didn’t rush.
I found a little bit of rust on the seat of the strut where the air bag would seat so I treated it with a bit of sand paper and some rust proof paint from buzz wield.
Whilst I had the front end in bits I replaced the front discs and pads as well as they were a bit nasty once I got the front wheels off. ( I did use island 4x4 for all my brake parts and they were great )
Post #521012 7th Jul 2019 9:38pm
Suggs
thanks, fortunately i have a mate thats a pro Landy mechanic and lives close by so he does any work to my car at mates rates. i dont trust myself lol
Post #521014 7th Jul 2019 9:49pm
