![]() | Home > Maintenance & Mods (L322) > car ramps |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
Personally, I wouldn't use them. Others may have a different view. John
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
I had a set of Machine Mart 2t (1t per side) start to buckle with my D3. I wouldn't risk it (and neither would I buy any car ramps from MM ever again!) 2016 Skoda Octavia VRS Estate
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
These any good to you? I know they show unavailable presently, (were about £120 a pair ISTR)
I've got a set of Rhino Ramps which are very good and much easier to lug around than metal ones. 2016 Skoda Octavia VRS Estate
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Buy a couple of OAK sleepers and saw in half diagonally 2/3 - 1/3
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
do them yourself for next to nothing |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
i have those plastic ones that split in two..very robust and they wont rust |
| littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 328
Hi Stan,
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
I'm not sure I want to use ramps that split in two! Be a bit careful with ramps. I used mine in the backyard on the grass and they were fine. A bit later, I wanted to degrease the engine so I put the ramps out in the front yard which is gravel (I'm a long time British car owner, all of which marked their territory). I got the RR halfway up the ramps when one slipped sideways nearly dropped it off the ramp. I didn't degrease the engine! Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
@littlecub, got these of ebay...
Thanks Stan,
| kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492
I have a set of the plastic ones but one piece that look the same as stans. Work really well and are very sturdy. I slip a couple of axle stands under for good measure but it's a belt and braces job. Plus the plastic ones are lighter than the metal stuff and less noisy too! Current 2007 TDV8 Vogue Buckingham Blue |
| gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287
I’ve also got these but from Amazon. I saw Bodsy use something similar when getting the gearbox flushed at Dr Robs place. Steve. |
Thanks all for the tips on using the plastic jobby ones.
| All times are GMT |
