Home > General > Westminster 4.4TDV8 2012 Odd Specification ? Opinion Please?
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi,
I have seen a nice spec RR Westminster.
Miles away from me, makes it awkward for warranty work, 3 months with the dealer.
However, can someone help me with the spec please?
Its says on the VIN Data from JLR that the Car has "Cruise control" but does not mention, "Adaptive". Was Adaptive standard on Westminster?.
Also, there is the following
Front driver and passenger memory seats
4 Zone Climate Control.
BUT!
It has rear seat recline (REAR SEAT RECLINE POWER)
The Lumbar Support has been removed (LESS REAR SEAT LUMBAR ADJUST)
The rear seat cooling that I thought was also standard on Westminsters of the MY has been removed (HTD/COOLED FRONT/HTD REAR)
It has other good spec, surround cameras etc. Also Rear screens which I assume are RR fit, not sure what the VIN feature terminology is for this.
Anyone have any thoughts please?
Post #521259 9th Jul 2019 7:56pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
my westminster has cruise but its not adaptive. heated and cooled front but heated rears only. 12plate 4.4 Cheers
James
Post #521262 9th Jul 2019 8:02pm
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Never thought Westminster came with rear cooling and I always thought no lumbar support anyway, even if rear seats do recline.
Post #521270 9th Jul 2019 8:37pm
Rob99
Same for mine too. Not sure what the option list might have been though as it was the run out model before the L405 so the spec was a bit quirky. 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #521276 9th Jul 2019 9:03pm
Rob99
If you have a link to the car details then others may be able to help. It might have been a forum members previous car Shocked 2017 4.4 SDV8 Autobiography
Post #521277 9th Jul 2019 9:04pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Mine has heated and cooled front and rear.
Post #521278 9th Jul 2019 9:06pm
TeeMyob
Or snap it up !
Post #521280 9th Jul 2019 9:11pm
Rob99
Haha, true........best keep it to yourself Whistle
If it's not local to you then it might be worth just listing out everything you think it has from the build sheet and then asking the dealer to confirm if those things are actually on the car. 2017 4.4 SDV8 Autobiography
Post #521293 9th Jul 2019 11:08pm
TeeMyob
60,000 miles, only one Official LR Garage service @ 25,118 miles 2016
Making me a bit nervous......
Post #521317 10th Jul 2019 9:04am
Bradders
Were the rest of the services carried out by LR specialist indys or just any old garage and what was the frequency/nature of the services ? Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #521321 10th Jul 2019 9:25am
Weegie
Re: Westminster 4.4TDV8 2012 Odd Specification ? Opinion Ple
TeeMyob wrote:
Hi,
BUT!
The lumber seat support would never have been there rather than removed. The terminology is the way JLR put it on their build sheets.
At 60,000 it has done pretty much average to low mileage for the year. How does the MoT history pan out re- annual mileage and reported faults?
Also, as has been said above, what does the service history say regarding who has done it? John
GAP iiD BT
Post #521323 10th Jul 2019 9:45am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I Think you will find it was only the SE had adaptive cruise control as standard and maybe the AB
Post #521325 10th Jul 2019 9:53am
TeeMyob
Hi,
Sorry. I meant not fitted like the Autobiography option. And the the rear seats did not have cooling like I thought they had
Post #521326 10th Jul 2019 9:53am
TeeMyob
Date tested
21 February 2018
PASS
Mileage
47,538 miles
MOT test number
9173 8482 0736
Test location
View test location
Expiry date
6 March 2019
Advisory notice item(s)
Windscreen has damage to an area less than a 10mm circle within zone 'A' stone chips. (8.3.1a)
Sub-frame rubber bush deteriorated but not resulting in excessive movement all four bushes (2.4.G.2)
Front brake disc worn, pitted or scored, but not seriously weakened heavily lipped. (3.5.1i)
Rear brake disc worn, pitted or scored, but not seriously weakened heavily lipped. (3.5.1i)
Offside Rear tyre valve deteriorated.
Nearside Front Tyre worn close to the legal limit heavily worn inner and outer edges. (4.1.E.1)
Offside Front Tyre worn close to the legal limit tyre heavily worn inner and outer edges. (4.1.E.1)
Offside Rear Tyre worn close to the legal limit wearing low inner and outer edges. (4.1.E.1)
MOT history
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
Date tested
9 February 2019
PASS
View test certificate
Mileage
55,334 miles
MOT test number
6408 1234 7562
Test location
View test location
Expiry date
6 March 2020
Post #521327 10th Jul 2019 9:56am
Bradders
Mine too. Poverty spec Rolling with laughter Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #521328 10th Jul 2019 10:01am
