Home > Technical (L322) > Noise from power steering when turning right.
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Lately I've had an increase in noise from the power steering when turning right.
It seems to be at a specific front wheel angle, possibly indicating an internal leak in the rack?
Noise is much like when you're at full lock, only less.
Car's got 150k miles.
Anyone had this issue? 2007 L322 3.6 TDV8 Stornoway
Post #521412 11th Jul 2019 6:17am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Have you checked fluid levels?
Post #521414 11th Jul 2019 6:58am
S.Hafsmo
Fluid level i ok. I've also changed the fluid (using correct LR Cold climate fluid). 2007 L322 3.6 TDV8 Stornoway
Post #521416 11th Jul 2019 7:42am
S.Hafsmo
None who have experianced such conditions? 2007 L322 3.6 TDV8 Stornoway
Post #522679 24th Jul 2019 8:20pm
gavinn
The noise that you are hearing which is the same as the full lock noise is the spooler valve venting pressure , either your PAS pump needs attention (recon unit) or your rack is on the way out and you have fluid pressure imbalance causing the spool valve to activate.
The spool valve is in the PAS pump i forgot to mention.
Personally i would live with it as a totally knackered pump or rack is the same price as replacing one that is just a little noisy !
Post #522682 24th Jul 2019 8:35pm
S.Hafsmo
As long as none of the offending articles are spewing metal debries into the system, thus making short work of other seals, I agree with living with it a while longer.
I would assume a pump failure would produce different symptoms? More consistent noise during pump load? 2007 L322 3.6 TDV8 Stornoway
Post #522683 24th Jul 2019 8:43pm
