Home > Technical (L322) > L322 2012 TDV8 Westminster Fuse Box location
Mark T Boldry
Simple eh..?
I recently had a fault with my car trailer lights which caused a failure of the towing socket fuse (I hope).
All other trailer lights work still, turn signal and brake lights, but not the tail lights..... My research tells me that the towing sockets are in a separate fused circuit and again on the internet, locations of these fuse boxes are pointed out.... But NOT for my model.. The 2012 L322 TDV8 Westminster (UK RHD spec).
Can anyone shed some light (excuse the pun) on this for me please...
Many thanks in anticipation...
Mark.
Post #521419 11th Jul 2019 7:31am
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Would assume its in the rear fuse panel. Is it not listed in the handbook? Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #521423 11th Jul 2019 7:50am
Mark T Boldry
Sadly, the appropriate year model handbook supplied to me isn’t correct for my car (it’s much earlier).. Sad
Post #521424 11th Jul 2019 7:52am
ianmacd
Manual's on topix. If you haven't got an account yet, then you can register for one and then browse things like owners manuals and accessory fitting manuals without a paid subscription: https://topix.landrover.jlrext.com/topix
A quick look suggests its fuse 27, a 10A fuse, in the front box (behind the glove box, does anyone actually have gloves in theirs?????). Current: RR L322 2010
Post #521428 11th Jul 2019 8:25am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
This is from 2010-2012 handbook
http://www.fullfatrr.com/gallery/albums/userpics/19698/fuses.pdf Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #521429 11th Jul 2019 8:26am
Rob99
The full 2010-2012 owners manual is in the Wiki......
http://www.fullfatrr.com/gallery/albums/us...manual.zip 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #521446 11th Jul 2019 9:35am
Mark T Boldry
Many thanks Ianmacd, Bushy30 and Rob99.
Have found the blown fuse and will be able to sort out the trailer lights once I get a replacement fuse.
Mark T Boldry
Post #521450 11th Jul 2019 10:08am
