Home > Technical (L405) > stop start |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
this apparent fuel saving feature is really bugging me and i would dearly like to switch it off permanently, but for my year its not that easy ...
10th Jul 2019 10:59am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3721 |
Oddly Stan my wife new car has this feature, and I don't think you can switch it off (otherwise I would have) but I have grown to be OK with it and the way it starts the car before pulling off is almost magical. Obviously I wouldn't have it on my RR but is OK on her Mazda Geoff |
10th Jul 2019 1:52pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
I quite like it Stan, saves all the vibration of the Derv engine when stationary! |
10th Jul 2019 2:59pm |
@geoff, you can do yours very easily ..
10th Jul 2019 4:53pm |
My old thing doesn’t have it or its already switched off Geoff |
10th Jul 2019 5:15pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
My 2015 4.4 AB doesn't have it !!! 2015 4.4 AB
10th Jul 2019 8:43pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1081 |
Just get it in the start routine. Foot on brake press start press stop start press handbrake letters not necessarily in the right order |
11th Jul 2019 7:45am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
I've disabled it on a few cars but only by getting to the switch wiring. A small module with 2 timers, the first one waits 30 seconds when the ignition is switched on, the second timer then operates a relay for 0.5 seconds simulating the button beig pressed. 1/2 dozen components and 4 wires sorted. BMW i3 Electric Car
11th Jul 2019 8:47am |
sounds complicated john....
11th Jul 2019 9:31am |
My first attempt was similar and quite easy to short the switch out, many systems however look for the changing state and if they see it permanently closed or open will signal an error etc hence why I did the two timer idea which works just like the switch being manually pressed, the initial pause is to give the engine time to be started and then it defeats the stop/start before youve driven off the drive. BMW i3 Electric Car
11th Jul 2019 9:37am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3741 |
https://rover.ebay.com/rover/0/0/0?mpre=ht...2352078637
11th Jul 2019 10:13am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1349 |
^That looks interesting Mike, although I wouldn't necessarily believe their claim it doesn't affect the warranty.....
11th Jul 2019 10:25am |
good spot mike, i'll look into this ..
11th Jul 2019 12:27pm |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1202 |
Stop start is really irritating , all be it for some, & I’m some! London drivers may have a different view.
11th Jul 2019 5:06pm |
