Home > Maintenance & Mods (L405) > Front brakes
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
Front brakes
I’m some new front discs ASAP. They’re definitely warped. Can feel it on the pedal. On this note I’ve been doing a bit of homework. I’m now 99% sure a set of Brembo callipers and discs will go straight on from an svr sport etc. While I’m sure this mod wouldn’t bother a lot of people is there anyone that has anymore info?
I know on the discovery you can fit the bigger brembo’s, callipers and discs straight on. All you have to do is remove the back plate. Also on the disco the servo is exactly the same as the one fitted to the supercharged sport. Not sure if this is the same with the l405?
Of cause all this work and money is just for the look of big callipers and discs because I think the stopping power is more than adequate on the standard set Up.
Post #521636 13th Jul 2019 9:40am
Any L405 Brembo setup will fit... 4.4 TDV8 or 5.0, they are all the same... The SVR callipers are painted bright red, standard are grey in colour Thumbs Up
You need callipers, pads, disked & back plates sir Thumbs Up
Post #521658 13th Jul 2019 4:48pm
Felstmiester
Cheers Craig. So are they all the same callipers? Seems to be a lot more stuff up for sale from the sport. Also need to find part numbers to see if servo’s are the same.
Post #521660 13th Jul 2019 5:20pm
gettingold
Try Advance Factors, they’ve got a 10% discount this weekend ends Sunday night. Code is “TEN”
Steve.
Post #521661 13th Jul 2019 5:33pm
