Home > Technical (L322) > L322 MY 10. TDV8 gearbox ID tool reading
sunripe
Spain
Good afternoon
I start getting problems of shifting and couple of limp mode with fault on gearbox. Attached is a screen capture of idtool, anyone can see what is wrong? Seems to me gear 5 always giving this high reading. Thank you for any help.
Post #521664 13th Jul 2019 6:18pm
ur20v
A Trap
Possibly the solenoid for that gear has failed, it is quite common and not too hard to source the service items and fit.
Post #521671 13th Jul 2019 8:14pm
RRPhil
EDS 1 controls the A clutch and is a ‘yellow cap’ solenoid, so the pressure it feeds to the clutch increases with increasing current. 0.048A is the minimum solenoid current so the A clutch is ‘off’. This applies to gears P, N, R, 5 & 6.
EDS 2 controls the B clutch and is a ‘blue cap’ solenoid, so the pressure it feeds to the clutch reduces with increasing current. 0.848A is the maximum solenoid current, so no pressure is being fed to the B clutch i.e. it is ‘off’. This applies to gears P, N, 1, 2, 4 & 6.
EDS 3 controls the C brake and is a ‘yellow cap’ solenoid. Maximum current measured on this solenoid means that the C brake is fully engaged. This applies to gears 2 & 6.
EDS 4 controls both the D brake and the E clutch and is a ‘blue cap’ solenoid. Which of the two is being controlled depends upon the active state of another solenoid – MV 1 – which is a simple ‘on-off’ solenoid. If the MV 1 solenoid is ‘on’ the EDS 4 solenoid controls the E clutch (gears 4, 5 & 6). If it is ‘off’ then EDS 4 controls the D brake (gears P, N, R & 1). The table does not appear to show the status of the MV 1 solenoid so we can’t tell from this which of the two is being activated.
EDS 5 controls the transmission’s main hydraulic system pressure and is a ‘blue cap’ solenoid. The current of 0.776A therefore means that the main system pressure is fairly low. In the event of an electrical failure, zero current on this solenoid therefore generates maximum system pressure to ‘get you home’.
EDS 6 controls the torque converter lock-up clutch and is a ‘yellow cap’ solenoid. The pressure applied to the LUC is proportional to engine torque and, in this case, the solenoid is at about half of its maximum pressure.
The only combination that would make sense for these solenoid currents is that the transmission is driving in 6th gear (with the MV 1 solenoid applied).
Phil
Post #521685 14th Jul 2019 12:41am
sunripe
Spain
Thank you very much Phil for the professional response. I just did gearbox maintenance, filter, rubber joints and filter, can be needs more oil?? TY
Post #521699 14th Jul 2019 11:07am
sunripe
Spain
Sorry I forget to say I was at 120 km h in 6 gear on highway.
Post #521700 14th Jul 2019 11:08am
RRPhil
Did you follow the correct level-setting procedure (and, in particular, did you have the engine running while you set the level)?
Did you also use the right fluid (ZF Lifeguard Fluid 6)?
Phil
Post #521701 14th Jul 2019 12:10pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Great explanation Phil, very informative Thumbs Up Bow down Cam
2011 TDV8 Vogue in Stornoway Grey
Post #521765 15th Jul 2019 10:54am
sunripe
Spain
Level done following instructions, all good, but still getting limp mode some times, here is the reading right before I got limp .ode.
Post #523014 27th Jul 2019 9:02pm
RRPhil
Unfortunately, information on the solenoid currents just before failsafe was triggered doesn’t really tell us anything. What we need to know is what error code has been stored (e.g. P0705, P0734, P0787, etc.) as this explains the reason failsafe was activated.
Phil
Post #523143 29th Jul 2019 9:03am
sunripe
Spain
Here are the 3 ecu error codes.
Post #523145 29th Jul 2019 9:20am
RRPhil
Sounds like a loss of communication between modules rather than a specific transmission error. Have any electrical connectors been disturbed or disconnected/reconnected recently?
Phil
Post #523288 30th Jul 2019 11:35am
sunripe
Spain
Phil
It makes lot of sense what you say, but the problem only happens when in 6 gear and push for more revs a bit harder and goes down to fith , then goes to limp mode.
Can be low amount of diesel as engine ask for more?? Never happens in low gears.
Post #523346 30th Jul 2019 6:49pm
