Home > Technical (L322) > Adaptive Dynamic Fault L322.
Mikem
United Kingdom 2010 Range Rover Vogue TDV8 Atacama Sand
After some advice I had the active dynamic fault come up on the dash , I have replaced both sides with the genuine wiring repair kits but the warnings are still on the dash and unable to select any special programs.The model in question is a 3.6 facelift model L322 all advice much appreciated
Post #521105 8th Jul 2019 7:25pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Air suspension working as it should? Cheers
James
Post #521110 8th Jul 2019 7:56pm
Mikem
Hi thanks for your reply, yes all suspension working fine
Post #521112 8th Jul 2019 8:13pm
Andy B
Hi Mike, had this on my L322 S/C and fixed it with the wiring kit (x2). Assume it's the Adaptive Dynamics fault, not Active Dynamic. Happy to pop round and take a look depending on where you are in Kent!
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #521117 8th Jul 2019 8:44pm
Mikem
Hi Andy yes it’s the adaptive dynamic fault, I am down in Folkestone many thanks for the reply
Post #521122 8th Jul 2019 9:08pm
Andy B
Ha, my home town and where I was dragged up (Dolphins Road)! Can arrange a visit in the next couple of weeks if you need some help I am popping down to visit my Dad in Seabrook in the next couple of weeks. PM me Very Happy SDV8 AB MY 2019
Post #521124 8th Jul 2019 9:16pm
Mikem
Will do many thanks for your reply
Cheers Mike M
Post #521125 8th Jul 2019 9:19pm
Mikem
Forgot to put i am only about 5 mins from Seabrook
Post #521127 8th Jul 2019 9:20pm
Mikem
Checked the connections yesterday on the 2 new wiring repair kits and all seemed ok but the warning light is still coming on could there be another fault has anyone else experienced this
Post #521698 14th Jul 2019 10:55am
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Have you confirmed it was definitely the fronts with a iidTool or similar?
I thought my fault was the front but when investigated they had been replaced already.
I got a iidtool & when checked it was actually the rear.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #521708 14th Jul 2019 3:43pm
Mikem
Had a broken wire on the front so replaced both sides going to get into somewhere that can plug it in and hopefully trace the fault. Thanks for the reply
Post #521711 14th Jul 2019 4:27pm
Mikem
What did you have to replace on the rear of the car
Post #521712 14th Jul 2019 4:28pm
RJH
I had to replace the wiring & connector.
It's the same issue the front has but less common as there's little movement so less stress on wiring In the rear.
https://www.fullfatrr.com/forum/topic51958...f60cfe8442
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #521735 14th Jul 2019 9:46pm
Mikem
Cheers rob will check tomorrow i have a spare repair kit if required
Post #521736 14th Jul 2019 9:52pm
Mikem
Checked the rears tonight no broken wires at the plugs so i think next thing is to get it plugged in and see what comes up Sad
Post #521803 15th Jul 2019 6:01pm
