Home > Maintenance & Mods (L322) > Cattle Grid shudder at 50MPH to 55MPH |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
My TD6 Gearbox was reconditioned during the previous ownership including the torque converter and oil cooler. Recently the usage tripped 50000 km since the rebuild so I did a fluid service. The Gearbox has been perfect however I was surprised at the state of the fluid, not burnt but brown and opaque, not red and clear. I was happy to find no metal particles just a thin slime on the magnets. Any easy Diy with new oil and filter, I drained about 6 1/2 to 7 liters undoing the cooler lines to drain the cooler as well. I can see how easily the filter would become clogged after prolonged milage. I would urge anyone with a TD6 to service their gearbox at 30k mile or 50k km intervals. For anyone in Oz, The filter kit with gasket is part number is RTK130. This is a Ryco brand part number, not listed for a Range Rover but 100% correct, unlike the Holden ones for the same gearbox. Mine was A$37 shipped from an eBay seller 2007 TDV8 VSE
24th May 2019 2:33am |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 292 |
Hi I did the same I recently had the gearbox fluid and filter changed and the oil was dark brown taking into account that the gearbox and torque convertor were reconditioned only 35000 miles ago! This just shows that this needs to be done every 50000 miles maximum to prolong the life of these crap gearboxes and torque convertors! I thought that I had a faulty fuel injector on Cylinder 1 so I replaced this had no shuddering for a few days but now its back! It actually seems as if there is no shudder when the car is cold but when warmed up on a long run the shudder is there in full force at 55MPH at slight acceleration! Any more ideas guys as this is really doing my head in and I'm considering selling the car now! Also at slight throttle in 1st gear after a long run feels lumpy and rough but when I give it more throttle its fine. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
24th May 2019 12:55pm |
I agree with the fluid change but must add, if the lock-up clutch is the cause of the judder, using Sport mode can get around the judder. If that's the case A fluid and filter change will hopefully sort out the judder. I can't see why its anything to do with cooling of the fluid, its the clutch in the torque converter not gripping due to being worn out or the fluid being too contaminated. Change the fluid or torque converter and fluid is the hopeful cure. I know which I would try 1st. 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
24th May 2019 1:20pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 528 |
I think mine is sorted - biding rear calliper, swapped out for a new one yesterday (at the supplying dealer's expense!). So far so good although I've only had it up to vibration speed briefly, but I'm confident it will have sorted it, the calliper was very obviously binding. 5.0 S/C Autobiography
25th May 2019 6:50pm |
MikeSpike Member Since: 19 Oct 2018 Location: Benoni Posts: 7 |
I can elaborate on that same issue. I had the cattle grid shudder under load switching between 3rd and 4th gear. I also had a knock when driving from stationary to around 30km/h.
30th May 2019 11:50am |
Hi thanks for reply and glad you got it sorted.My issue doesn't seem to be under load and is only apparent at 55MPH so when the 5th gear is engaged. I only have the issue the shudder if I take foot off gas and re apply at 50MPH and slightly accelerate to 55MPH I get the shudder. If I select Sport mode and do the same I get no shudder! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
30th May 2019 12:33pm |
I ran test with my IID tool today and at a steady drive of 40 MPH my fuel comp readings were from CYL 1 to 5 reading 654 and CYL 6 reading 8 to 10 fluctuating. Also when I stopped I put car in park and maintained revs at 2000RPM I had a noticeable shudder and the read on Cylinder 6 was again 8 to 10 fluctuating.Any ideas guys I also get this annoying shuddering effect as if car wants to stall at slight acceleration.
24th Jun 2019 3:24pm |
https://www.youtube.com/watch?v=vFNNnd5mSTc 2007 TDV8 VSE
25th Jun 2019 6:18am |
Thanks for that Wayne its a strange one as at idle I get readings of 654mm3 at CYL 2 ,3 , 4 and 5 if anything over 4mm3 is bad then surely 654mm3 isn't good! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
25th Jun 2019 11:20am |
Hi guys quick update this issue turned out to be a faulty injector CYL 5 really strange as the leak off test gave nothing away and my fuel consumption readings were all fine on tick over its was only when I decided to take a reading when reversing that I noticed CYL 5 gave a reading of 10mm3, The other strange factor was the cattle grid shudder only present at 55MPH and no other speed which I was advised was classic Torque Convertor symptoms. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
11th Jul 2019 10:31am |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 |
i think above 55MPH the TC LUC is locked so it may be that at this speed you feel 100% of the engine vibrations from misfire/poor injection etc. at speeds below this you may well have the same issues ongoing but the TC LUC isnt always 100% so there is some damping in there.
15th Jul 2019 1:19pm |
