![]() | Home > Technical (L405) > Tailgat not functioning |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 ![]() ![]() ![]() |
I never know if mine will work from the fob or not but it always works from the switch by my knee or the switch on the tailgate.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8106 ![]() ![]() ![]() |
My lower tailgate won’t close. Opens fine & the upper section is fine - but I’ve just learned to live with manually closing it. |
EdJ Member Since: 30 Jan 2015 Location: London Posts: 367 ![]() ![]() |
In my last L405, the tailgate sometimes didn't open with the key due to - I presumed - low battery. It would often then work as normal when I'd driven somewhere, and the battery had been charged a little. 2024 Range Rover P550e AB |
peanutbob Member Since: 03 Mar 2013 Location: UK Posts: 57 ![]() ![]() ![]() |
My lower tailgate stopped functioning using the remote. I noticed that, having dogs, there was some dirt/sand in the recesses at the rear of the gate. After sucking it all out with a Henry, it worked again.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3947 ![]() ![]() ![]() |
Mine sometimes won't close from the key unless I press the unlock button first (car already unlocked) Geoff |
