![]() | Home > Technical (L322) > Restricted Performance fault TDV8 4.4 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
The secondary turbo change-over valve may be sticky - the original design's external linkage was problematic.
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Thanks Graeme, just trying to google pics of it so I know what I am looking for ..... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
I think the EGR readings are a bit of a red herring sir as the 4.4 only gets one EGR because of the sequential turbo's... |
https://www.fullfatrr.com/forum/topic49556.html?highlight=csov |
Thanks for the info CTC |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3848 ![]() ![]() ![]() |
LTB 00504 v3 dated 18th February, 2013.
Thanks Mike - I have googled that reference from one of your other posts but nothing comes up - don't suppose you have a copy of the TSB?
Paul,
That's perfect thanks |
I've checked and mine does have the nut, am dribbling oil on it during the course of today so will see if it makes a difference. Hoping this is the problem but need to try and isolate to be sure, I am guessing the difference in readings on the bank2 boost live values is the give away but we will see |
I think I would be tempted to take the nut off, then give a good squirt of WD 40.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
mm289,
Cheers, Nino |
