![]() | Home > Maintenance & Mods (L405) > L405 sdv8 4.4l oil leak |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
The 4.4 can be a bit leaky.
Ielk2001 Member Since: 17 Jul 2019 Location: Worthing Posts: 8 ![]() ![]() ![]() |
Thanks. As I've already negotiated a very decent deal, my plan is to go ahead and hope for the best. But was curious if you had any ideas based upon experience? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3848 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic35977-300.html
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I have an oil leak on my 4.4 SDV8 on the seal between the engine and gearbox (it wasn't there 3 weeks ago) . I have done 55k miles in the car which is 5.5yrs old and to replace the seal involves removing the gearbox and so the main dealer cheapest quote for me is £1,100 so going ahead as I don't want to risk any form of engine failure due to lack of oil as that would make this seal change cost insignificant. Steve
Oh no sorry to hear that. I'm just confused a) why these cars are so popular and b) why, after all this time, land rover cannot make a reliable vehicle. That said, it isn't stopping me buying one... |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
Is it certain that the oil is leaking from the rear seal rather than running down from the top at the back of the V from a leaking oil cooler? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7964 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic35830.html
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3804 ![]() ![]() |
It could simply be the oil filter and it’s seal that isn’t fitted correctly - located upside down on top of engine. I had this on a 12 month old L322 4.4 TDV8 which is essentially the same engine.
Interesting you should say that as there was no apparent leak when it was in 3 weeks ago - for an oil change!! I'll have them check the filter - thanks Steve
I invested £5 buying a 36mm socket, because it is the best way to be sure the filter is refitted to the correct torque.
Just a quick update as according to the dealer who says it has been in to a specialist to have the oil leak investigated it is "slight misting from the turbo". I've been told (by the dealer) that it is fine for now and that in any case a failure to the turbo would be covered by the warranty. Any thoughts? Sound reasonable? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1393 ![]() ![]() |
Tell them to fix it.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
My 322 TDV8 (substantially the same engine and turbos) had a misting oil leak on one of the turbos. Dealer advice was that it was not bad enough to warrant intervention and that it should just be monitored. It was fine for the rest of the time I had the car and did not seem to get worse.
Thanks all. Dealer has agreed, as condition of sale, to allow me to get oil leak investigated at my expense and for them to rectify at their expense. I think that's pretty reasonable so will get a RR specialist to investigate! Will let you know the outcome in case you come across it! |
