Home > Technical (L322) > REMOVING ROOF BARS |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Water can't leak into the car if you remove the roof bars but if you want piece of mind until your new trims are ready you could always just tape over the openings in the meantime. |
17th Jul 2019 11:59am |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Thanks for this buddy.
17th Jul 2019 12:12pm |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 201 |
If you haven't got the covers on then you might want to put some screws back in in case you ever want to use those threads again. They are usually supplied with a grub screw in there which need to be removed before fitting anything but guess you didn't get given them (not surprised as dumped the ones I took out too). Current: RR L322 2010
17th Jul 2019 1:14pm |
17th Jul 2019 1:17pm |
