![]() | Home > Maintenance & Mods (L322) > Rust on RHR wheel arch |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
Plastic sill needs removing to check for any additional rot Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Probably lots of rust under the plastic. I had holes in both sills.
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 213 ![]() ![]() ![]() |
Thanks for the tips, guys - do they come off easily? L322 TDV8 4.4 - current
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 ![]() ![]() |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Seems like this is rusting from outside - in? Is it caused by dirt stuck between plastic and metal?
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
I've not been on the forum for a while, and just posted a very similar post in the tech section. Seems I was a lot luckier than a lot of people. It has to be sorted early was my message and we have to stay on top. It's a sin that such a highly thought of (and bloody expensive) vehicle has such a vulnerability. Good luck with getting it sorted. |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
They come off easily yes. Pull out the centre pins under the bottom of the plastic sills. Remove the nuts from the mud flaps if fitted the open the rear door and prise the plastic from the metal sill and then do the same with the front door open. Current 2007 TDV8 Vogue Buckingham Blue |
Thanks again for the input, especially kbald- I'll keep you posted! š L322 TDV8 4.4 - current
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 ![]() ![]() ![]() |
I have the same problem both rear jacking points collapsed. Anyone had the skills replaced and got an idea of cost? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Having seen some of the above examples of corroded sills, bit the bullet today and took the sill covers off my 2004 TD6.
How did it look? 2007 L322 3.6 TDV8 Stornoway |
Feeling very guilty, still not done it as other crocodiles were closer to the canoe, but will keep you posted! š L322 TDV8 4.4 - current
