![]() | Home > Technical (L322) > L322 misfires bank 1 help :( |
| TopCatFCD Member Since: 06 Sep 2018 Location: Drumnadrochit Posts: 9
L322 2006 4.2SC 118k on clock. Got it around 6 months ago.
OK I've put coil packs back on "original" cylinders but misfire in 4 is still there. So now I've got misfire in 1,3,4,5,7.
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419
Given the number of miss-fires and originally all on one bank then it points to an issue that's common to all of them which will be unlikely to be individual coils or injectors (unless common wiring to them or you are VERY unlucky!).
Thanks! I'll see if I can have someone do smoke test for me and see if it's that. My vacuum pipe(?) had popped of at back of engine and I've cleaned that and put back in along with some shrink tube to hold in place. Engine did not sound any different after doing this so maybe that indicates what you're saying is what's happening here.
In case this is of use t o anyone in the future.
No idea how they worked it out but it looks like the sensors were basically restricting fuel and making bad mix due to cat upsetting readings and this causing misfire.
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2298
Did you fix this? Current stable:
Hi, yeah was bad cat. Thing was totally bored and causing dodgy readings for the O2 sensors. No issues since |
| Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 114
I too had a cat failure and now waiting for the other one. . . Range Rover 4.2 SC
I see thanks Current stable:
| Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 247
THIS IS EXACTLYWHATSHAPPENING TO ME!!!
| All times are GMT |
