![]() | Home > Technical (L322) > EAS issue |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6420 ![]() ![]() |
Have you tried the battery disconnection procedure, along with the touching of the two terminal cables ?
T20bigjim Member Since: 13 Jul 2019 Location: Wisbech Posts: 12 ![]() ![]() ![]() |
Yes I’ve tried that. The consensus seems to be it doesn’t cure a hard fault though.
Was thinking more about getting the EAS to a state where it was happy to be read by the diagnostics instead of ignoring it. You are correct is will probably not solve a hard fault (has been known, but rare).
The fault won’t clear from the ABS ECU |
at all, or it just comes straight back? .
Have you checked all the wires / connections to the OBD port ? .
Won’t clesr at all. I’ve tested the wiring continuity from the OBD socket to the cluster, and cluster to the EAS. All checked out. |
Just checked wiring diagram again, I’m certain I tested every wire at the socket but will do it again. The common denominator between the EAS and airbag ECU is the K line. |
Have you ever been able to read the EAS ecu / codes with your Solus ? .
I only bought the car a few weeks ago with this fault. That’s why I took it to a landrover specialist to see if they could access the codes. |
and they couldn't access the EAS codes ? What diagnostic kit/software were they using ? .
They use Autologic, |
Really going nuts here now!
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Have you disconnected the LCM? If not, try it and then check if you can access the EAS and Airbag modules. |
