Home > Maintenance & Mods (L322) > Injector cleaner for a 2006 4.4 Jaguar Range Rover |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
How long have you owned it?
16th Jul 2019 6:10pm |
kirton Member Since: 24 Jan 2014 Location: Crediton Posts: 48 |
I have owned it for about 6 years. I had the LPG system installed, it is BRC.
16th Jul 2019 6:44pm |
Valve saver system tries to combat valve seat recession when lpg converted, the jag engine needs it, get a leak down test to confirm whether you have an issue or not.
16th Jul 2019 7:03pm |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
Hi
17th Jul 2019 8:10am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Has anyone ever experienced this on a car without lpg? Chaps who have/had the problem what were your fuel trims like? Mine are low on the long term (3 to -3 ) but short term they are up to 20
19th Jul 2019 10:43pm |
I put Forte injector cleaner into a half tank of petrol. The engine management light went out after less than 100 miles. Question is, do I still get the injectors cleaned or follow other diagnostics as suggested here?
21st Jul 2019 3:14pm |
Is it still bouncing about when on lpg as in your original post you said it was the same on both fuels a tank of treated petrol wouldn't have sorted out the lpg end would it |
21st Jul 2019 3:53pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
If its misfiring on either fuel I would think it isn't a fueling problem, as lpg will use different injectors to the petrol ones. So your problem should be mechanical (after the fuel system, e.g. valves) or electrical. |
21st Jul 2019 6:05pm |
