![]() | Home > Maintenance & Mods (L322) > Vsr symptoms? |
Are you talking about Voltage Sensing Relays ? In relation to what ?
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Valve seat recession/regression on the jag engines |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Never seen this (in the many cars I've owned) - the only thing I can think of that could cause the valve seat the deteriorate/recess is either the wrong fuel or spark plug (i.e the burn is incorrect), but never seen it personally. |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
I have seen it and experienced it on a AJ Engine running LPG , these MUST have the addition valve saver fluid dosing system fitted due to the cam being fixed shimmed, this does not apply to other engines with hydraulic lifters as they automatically adjust to the valve seat wear, but the jag engines have softer seats and fixed bucket style shims for the cam. |
