Home > In Car Electronics (L322) > Condensation in dvd/nav area
Danwilderspin
Hi all I had a massive water leak when I got the car all sunroof drains blocked that are now clear however I opened the nav door in the boot to change a disc and noticed everything appeared to be covered in condensation is that normal? I didn’t see big drop as before
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #522444 22nd Jul 2019 8:14am
Of course this is not normal Confused
Recommend remove all from the cubby
Dismantle each item as much as you dare, check for corrosion, on PCBs and connectors, and resolve (toothbrush / contact cleaner)
Commandeer the airing cupboard for a couple of days
Refit .
Post #522447 22nd Jul 2019 9:03am
Danwilderspin
Ok and how to fix the actual condensation coming back? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #522448 22nd Jul 2019 9:06am
This could simply be a hangover from the deluge you had in there previously.
If it comes back, then you must be getting water in there still.... .
Post #522453 22nd Jul 2019 9:56am
Twistedjack
United Kingdom 2006 Range Rover Vogue SE Td6 Bonatti Grey
It's not normal but could also be moisture that's from your initial leak. Did you manage to completely dry it out? Test the boot seal too, they're known for going.
Post #522470 22nd Jul 2019 1:31pm
Danwilderspin
the seal going around the top? jug of water test? I don't know if its all gone guess it could be damp under the carpets have ordered some of those pots off amazon that take the water out the air will leave them in for a few weeks. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #522471 22nd Jul 2019 2:03pm
Twistedjack
Yep, the seal that goes right round the boot. Sit inside with the boot closed and have someone pour water/hose it and you will quickly know if there's a leak.
Post #522506 22nd Jul 2019 8:05pm
Arch Stanton
I've been looking a t a few l322s over the last few weeks and some of them are missing a bit of trim from the edges of the rear window, does this form part of a seal or is it just for show? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #522515 22nd Jul 2019 9:56pm
Rogerisleofman
Isle Of Man 2014 Range Rover Autobiography TDV6 Luxor
My brother and I had matching 3.6 Vogues from new but delivered two weeks apart. Mine had the trim on the window, his didn't! But there was no noticeable difference in boot sealing because of the omission and both cars performed perfectly over the next 12 years. I wouldn't worry about the absence of external trim.
Post #522536 23rd Jul 2019 10:44am
