Home > Maintenance & Mods (L322) > Upper Tailgate lock fix
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Today I went to close the upper tailgate and the lock failed to engage. I did a search and found it was not that uncommon however apart from one reference to a fix with no explanation, all others changed the lock. Someone also asked about the light switch adjustment and again there was no fix found. Here in Oz getting used parts is not easy but I did find a breaker with a lock for A$180 so I knew I had a backup if I trashed mine trying to fix it. Anyhow I got it apart, found the fault and fixed it, all up about 45 mins start to finish and all is back to normal for no cost. The following is a picture tutorial also showing the light switch if anyone needs to adjust theirs.
You need to remove a metal cover by drilling out the rivets, then you can remove the plastic cover giving access to the workings. I can see the spring will rub over the years until the end snaps off.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #522706 25th Jul 2019 5:06am
wayneg
More
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #522707 25th Jul 2019 5:11am
kooky_guy
Thanks for that. Really clear! 2010 4.4 TDV8 Vogue SE
Post #522711 25th Jul 2019 7:39am
Nice fix, nice tutorial, how it should be done Thumbs Up .
Post #522716 25th Jul 2019 9:02am
nice job wayne, put in the wiki.. ... - .- -.
Post #522717 25th Jul 2019 9:16am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
A really helpful clear post. Thumbs Up Thumbs Up
Post #522725 25th Jul 2019 10:09am
Naki
United Kingdom 2003 Range Rover Vogue Td6 Java Black
A helpful guide, thanks. Mine has just stopped working now. So I will be attempting the same repair soon.
Mine is an 03 TD6, so I hope it’s the same on the early models. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
2003 L322 TD6 Vogue with Facelift conversion
2000 Discovery 2 TD5 ES. Daily
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #616937 19th Dec 2021 7:02pm
wayneg
Good to hear it's still helping others. That fix held up till I sold the car a few weeks back and presumably still going strong. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #616953 20th Dec 2021 1:01am
Naki
So, I did the repair today. Put it all back together, but oddly, the lock only does that funny “half lock”. Where it catches, but the tail gate still moves back and forth. I guess I will take it apart again and see if I can see anything obviously wrong?
Any ideas what’s gone wrong? 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #617056 20th Dec 2021 11:05pm
Naki
Here’s the lock 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #617058 20th Dec 2021 11:11pm
wayneg
I can't offer any advice however it's interesting to see my lock was completely devoid of any grease compared to your one that's well lubricated. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #617067 21st Dec 2021 12:55am
Naki
I added spray white grease. There was some yellow multipurpose type grease there already, but I thought add some more. I assumed it would be the last time it was opened. But something is not quite catching properly. So I will go back in again tomorrow. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #617068 21st Dec 2021 1:02am
wayneg
Probably a good move to grease it. Was your spring broken like mine?
I have tried to see if there is any apparent difference between our pictures, the only thing I can see is my switch lever has a definite bend in it, yours appears straight in comparison 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #617070 21st Dec 2021 1:51am
Naki
So, after further investigation today, it appears the latch/ lock is fully working, but not when the trim cover is fitted! As soon as I fit that the latch only does the half lock thingy. So I will leave the trim off for now.
It never fitted that well to begin with, though I had added some new clips for the usual missing/ broken clips, thinking it would help fix it. Where as it seems to have had the opposite result!
I think the clips are very slightly different? So it looks to be stopping the door from fully closing, even with a firm slam.
So in usual LR style, a 1hr job, turns into 1-2 days!
Oh well. With the tail gate trim off I have started investigating the on working rear screen wash. Blocked non return Valve, and possibly blocked jets on the wiper arm too.
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #617143 21st Dec 2021 5:43pm
Naki
At least the latch repair itself was actually successful though. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #617144 21st Dec 2021 5:44pm
