![]() | Home > Maintenance & Mods (L405) > LED door puddle lights |
| ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202
Was wondering about that for my 2017 too as its also not led from what I could see. Current: RR L322 2010
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
Less than 5 mins to fit but watch handling the removed originals as they get hot very quickly !!! 2015 4.4 AB
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801
my mirror lights project a 'range rover' logo onto the floor and i'm sure the door puddle lights are normal incandescent bulbs and they dont give out much light ... they might even not work??? so that you can see the RR logo... ... - .- -.
Hi Stan , mine does the same if you open the car using the remote or when you close the door you get the pic of a l405 side on. The door ones come on once you open the door ( or should ) i had noticed on mine it was a yellow light which led ( sic) to my search for LED replacements. The aforementioned company also do them in blue which could match the mood lighting if blue is what you have chosen. 2015 4.4 AB
gotcha |
| Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369
I’ve fitted these led lights to my 2013 SDV8 and they make a huge difference. Highly recommended. 2019 L405 SDV8 Autobiography
| Brunel Member Since: 10 Apr 2019 Location: Bristol Posts: 128
Hi Dolph
Hi Stuart , not sire if Stan would allow me BUT the name of the site is powerful uk and it easy to find, if Stan sees this ( pope / catholic) and gives the thumbs up then i will happily post the link. Otherwise pm me |
Ignore - have found on their site and ordered |
link is no problem john.. ... - .- -.
Thanks Stan
| Badger Member Since: 02 Jan 2011 Location: Bucks Posts: 170
The earlier L405's used to have RANGE ROVER in the puddle light projected down onto the floor from beneath the mirrors. Which looked really cool.
| adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 877
I can confirm, even the 2019 P400e has the incandescent bulbs, although with a blue tint... Replaced all with some CANbus safe led's from the supermarket... 1.3£ each... |
| Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 247
Ordered some will see how they go. -- On my third Full Fat RR |
