![]() | Home > Technical (L322) > Access mode..... |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
I have had a number of vehicles since my first P38A with air suspension and virtually always lower it. In fact, in my L405, I have selected the option to auto lower it when a door is opened. Current: RR L322 2010
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
I use it all the time. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Every time to avoid seat bolster wear |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Thanks All,
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
I use it all the time. However, if a door is opened whilst lowering then the lowering is stopped. I though it was a "safety" feature, to prevent lowering of door onto an external object. Is that not the case with the L405? |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
All the time coz of my little pins |
That’s what I figured. In my experience mechanicals seem to prefer to be used. Trust me, I used to drive a TVR! |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Can you do this on a 322? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I lower it pretty much every time. Makes getting in and out easier. Although I’m vain so it’s probably more to do with looks |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
I lower mine most of the time, for seat bolster preservation, wife finds it easier to get in, and to help the dog jump up into the back! I also have side steps which help a lot with the first two as well. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
Thats how it used to work on all my previous ones but there was an option in the vehicle settings (I think) that allowed easy access or something. I actually thought it was moving the wheel away and seat back wen the driver gets out but it seems to lower the vehicle when a door it opened. My L322 used to stop as soon as a door was opened as I used to moan at SWMBO always opened it while it was lowering despite me telling her 1 billion times not to ![]()
I am 99.999% sure you can not. Current: RR L322 2010 Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB |
On an l322 it shops when the door is opened but resumes when it is shut |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I used to lower mine every time I parked it because it looked better!
Great! Thanks folks... Looks like I'll continue to use as normal then. |
