![]() | Home > Maintenance & Mods (L322) > Front suspension stuck in off-road mode “Help” |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35856 ![]() ![]() |
the height sensors may be damaged or bent... ... - .- -.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Check Tail Light
Bogi 6357 Member Since: 29 Jul 2019 Location: Scottish Borders Posts: 54 ![]() ![]() |
I will swat up on that this evening and have a look, thank you for the reply |
Just looks like the standard 2008 Tdv8 rear lights , I will take them out and have a look at the bulbs and see if they have been replaced with an led version Thanks for the reply |
More likely to be the whole light unit, with new drilled holes for the fixings
Definitely the pre 2010 ones Joe
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140 ![]() ![]() ![]() |
If the boost hoses were leaking enough to hear it would normally cause a fault and limp mode. I suspect you have the same problem as me...exhaust manifold(s) leaking due to snapped studs. |
Ahh |
If it is indeed the problem it's not terminal at all, it'll just be noisy. It's simply annoying as you want this engine to be nice and quiet. Cam
Telly Addict , thanks I’ve been nursing the car with anxiety and paranoia just incase it is the turbos or if the exhaust manifold cause the turbos to fail for whatever reason
