Home > Technical (L322) > Remote Locking not working - 2 Button key
davidmg
2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
2006 Model Year Japanese spec 4.2 SC with a two button key 315Mhz
I have tried normal key sync proceedure but it will not work.
So does anyone know if there is a special way to sync the two button keys?
Post #523354 30th Jul 2019 8:35pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Well that's an interesting scenario, I'd be happy to take a look when we're passing or you could come this us.
www.lrkeys.co.uk Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #523360 30th Jul 2019 9:12pm
davidmg
Done a bit more research on Japan spec keys which apparently use an Infra Red system but key sync procedure is supposed to be the same.
The keys infra red is working so maybe the sensor at fault or BCM
Post #523368 30th Jul 2019 10:50pm
Bushy30
Best to start with reading any faults Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #523370 30th Jul 2019 10:52pm
