![]() | Home > Technical (L322) > let the wife down today |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
the range refused to start today, i left for work in my van and 2 hours later got a phone call from the ball and chain, that the stupid car wont start, when she puts the key in to start the car the steering column clicks repeatedly like a relay or something, so i talked her through how to check the battery voltage with a multimeter and its apparantly 12.73v and the battery is only 2 months old, anybody any ideas so i dont get an earfull when i get home, it was my idea to buy the range, she wanted an s-max, any help appreciated 2002 td6 vogue, 06 supercharged facelift
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Try the spare key - advice not based on experience or knowledge, but worth ruling the key out. |
she tried that first 2002 td6 vogue, 06 supercharged facelift
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
still sounds like the battery...can you use jump leads and see if that makes a difference.. ... - .- -.
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 ![]() ![]() |
Had something similar when i first got my TD6 turned out to be a faulty injector. Could be worth a check. |
Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 35 ![]() ![]() |
Darren,
stephen is correct, 110 amphrs with a 920 crank [td6] ... - .- -.
so fitted another new battery 110Ah 900a and still the same problem, when the key is placed into ignition switch the steering lock repeatedly clicks on and off and the key wont turn at all, could it be the lock itself or the transponder ring just above the ign lock or something else ? its doin my head in and the missus too |
darren. i sure i read somewhere that there are mechanics that get stuck and the key wont turn, try taking the console panel of and use a screwdriver to move it.. ... - .- -.
the steering lock or ign switch ? 2002 td6 vogue, 06 supercharged facelift
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
I had a similar fault in a BMW E38 (7 Series). It turned out to be the transponder from the key, or rather the unit in the steering column which receives the code from the transponder.
cant get the gearstick to move, is there a release mechanism somewhere ? 2002 td6 vogue, 06 supercharged facelift
ignition switch apparently..like BOZ says wiggle the gear stick into neutral and try the key.. ... - .- -. Y. O. L. O. . |
Yes , pull leather gaiter of the gear selector up and off the suround and them pull he gear leaver sharply up and off, you can now see the selector mechanism and on the right by the leaver in park is a release trigger for such times . Hope that makes sense . If you go to Powerfull' web site their is a video of removeing the gear leaver on the bit for buying a new trim surround . 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
