Home > Technical (L322) > BONG Suspension fault
jemj
England 2010 Range Rover Autobiography TDV8 Stornoway Grey
Hi guys, my new to me L322 has just thrown a wobbly at me (2010 4.4 TDV8 Autobiography). Not bad going as I have owned it for a 18 months now. Anyhow, we were on our way to Stratford when the dreaded bong happened. Suspension fault was showing in orange on the dash with a big orange triangle. I stopped and checked but could not find anything obvious, no air leaks, no corners lowering and no height sensor rods broken off. I decided to carry on as i could remove said message by pressing the OK button. We made it to Stratford without any problems and we parked up. I deliberately did not lower it to access mode as I usually do, just in case it wouldn't pump up. 6-7 hrs later we returned and car still up on all corners. Turned on ignition and BONG, still got the fault. We drove home, some 70ish miles without any trouble and then this is where I decided to lower it to access mode. Down it went, good so I raised it. Up it went, even better. Now to offroad height, yes again up it went up. Back to access mode and then up to road height. This where it exhausted the reservoir and would not raise fully. Okay so it is a compressor fault I thought. On to Fullfatrr.com for some answers. An hour or so later I went out to check out the compressor and blow me down it worked. Pumped up to all heights even though the bong and fault appeared as soon as the ignition was on. This now makes me think AIR LEAK causing compressor to overheat. Bags pumped up fully out came the leak detector spray. No leaks found on bags, pipework or compressor valve block ( I am a mechanic by trade and have worked on all manner of vehicles incuding every Landrover model made barring the latest ones). I will get access to Snap-on diagnostics this coming week but was wondering if anyone here has had this happen to them which might help with a quicker fix for me. Thank you all. The Best 4x4 by far, so long as you have deep pockets.
Post #523767 4th Aug 2019 8:52pm
Did you try going to off road height, then manually lifting each corner, listening for hissing air ?
Diagnostics will help identify the fault. Sounds like a soft fault if it goes away and then comes back, so not terminal, but does seem to indicate that air is escaping somewhere... .
Post #523773 4th Aug 2019 10:00pm
jemj
Hi Joe90, no I didn't try lifting it on the corners. I will try that tonight when I get home. The Best 4x4 by far, so long as you have deep pockets.
Post #523840 5th Aug 2019 5:47pm
Sharpy1980
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
what about the little wires to the tops of the shocks I heard these are a common weak point for breaking not sure on the symptoms tho gotta be worth a look L322 4.4 TDV8 Current
L320 3.6 TDV8 Going
L322 3.0 TD6 Gone
Disco 2 Td5 Gone
Defender 90 Gone
Freebie Td4 Gone
Disco 1 200tdi Gone
Post #523847 5th Aug 2019 8:08pm
jemj
Hi guys, I have plugged in diagnostics and found fault. The front nearside height sensor is faulty. No voltage output. I will get one ordered and hopefully be back on the road soon. The Best 4x4 by far, so long as you have deep pockets.
Post #523848 5th Aug 2019 8:16pm
Sad Thumbs Up .
Post #523852 5th Aug 2019 9:10pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
easy and cheap fix then pal Thumbs Up
Post #523867 6th Aug 2019 8:09am
jemj
Okay guys so not an easy fix as I thought. Part arrived today, pattern part and not genuine LR but I have never had trouble before using pattern. I ordered part number LR020626 which is supposed to be left hand front sensor for L322 up to 2012. I went to fit it and found that 1) it only had three pins and not 6 like my original and 2) it has locating pegs in the plug socket that do not fit my plug. My thinking is that because my car is the autobiography it has the dynamic adaptive suspension and the sensor I have ordered is therefore not for my car???? I do not have RAVE so can anyone help with the correct part number that I should be ordering?
Thanks in advance. The Best 4x4 by far, so long as you have deep pockets.
Post #524557 12th Aug 2019 7:27pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Maybe this will help
https://www.advancedfactors.co.uk/height-s...3821-c.asp 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #524564 12th Aug 2019 8:32pm
sniper
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Causeway Grey
make sure its not just a broken/shorted wire on one of the front shocks (under bonnet) i had this error just to find one of the wires had broken where it leaves the engine compartment to go into the body/strut, it was an easy fix with a soldering iron and some heat shrink.
Post #527075 4th Sep 2019 6:27pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
I had a sensor fault code and when I jacked the car up to change it there was a hole in the air spring. The sensor had thrown up a fault because the system was trying to inflate the bag and was expecting the sensor to react. Worth checking the bags first.
Post #527112 4th Sep 2019 10:52pm
