Home > Maintenance & Mods (L322) > Broken front offside door latch
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
The drivers door is closed and I can not get it open.
When the central door locking is activated there is the clunk when locking and unlocking as usual. The button raises and lowers.The inside handle will raise the button also. Both door handles won't then open the door.
I have prised the door card off and removed the airbag which gives a view of the lock.
Both door handle wires are intact, the outside handle wire pulls the mechanism ok but the mechanism fails to spring back as it should, when the mechanism is manually pushed back it makes no difference.
So I think it is safe to say the lock has broken in the locked position.
When the latch completely failed on the passenger door the Dealers smashed to lock off as they say there is no other way to get the door open !!
Has anyone any experiance of this or a detailed guide of how to smash the lock ? The rest I can replace no problem if the door is open. I am just concerned about doing any damage over and above what is needed.
Post #52344 1st Mar 2011 7:15pm
havnt done the door lock smash , but can you fiddle a screwdriver in the lock to see if the lock releases... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #52384 1st Mar 2011 9:35pm
RRRob
Although the door card is off at the top I havn't yet removed it completley so access is a little limited to the latch area. I have had a good poke about but what ever I do it seems to make no difference.
I have tried using the key but no luck that way either.
Post #52385 1st Mar 2011 9:40pm
certainly sounds like the lock itself is knackered ...hope you find an answer for this problem... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #52386 1st Mar 2011 9:47pm
paneldamage
Hi RRRob
No chance something is trapped in the door jamb? A bit of the setbelt? I had this, neither handle releasing.
The belt had stuck in the jamb and somebody slammed the door hard. I thought the cable had snapped when I first came to open it.
Solved it by lying across the seats and forcing the door open with me feet whilst missus held the outside handle open, the door was stuck solid then popped open like a cork out of a bottle. Just a thought...
best of luck
paneldamage
Post #52405 1st Mar 2011 11:39pm
love that, give a solution then sign it ''paneldamage''.....not very encouraging. Laughing ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #52427 2nd Mar 2011 9:37am
