Home > Technical (L322) > Found a vacuum pipe hanging ....
Andy
When I replaced the air intake tube last week I noticed a small bore black U shaped pipe between the two air supply tubes from where they fit onto the airbox. Mine is just hanging there connected to nothing.
Does anyone know what it’s supposed to connect to? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523991 7th Aug 2019 5:23pm
A breather pipe if it’s u shaped? 👍
Post #523992 7th Aug 2019 5:29pm
Andy
It’s hard black plastic and runs up along the air tubes and terminates in a U shape upside down. There is even a moulding on the tube to hold it in place. I assumed it pushed onto something. I thought I might’ve found the restricted performance fault there for a minute! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523996 7th Aug 2019 5:37pm
Your describing an axle/trans/ & transfer box breather pipe sir... they let the air in & out when in 80cm deep water 👍
Post #524068 8th Aug 2019 9:17am
Andy
Thanks Craig. Always learning on this forum! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #524070 8th Aug 2019 9:26am
Post #524078 8th Aug 2019 10:02am
