![]() | Home > Maintenance & Mods (L322) > 3.6 TDV8 inlet manifold repair |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
I used JB Weld first. Lasted about a week then heat expansion made the repair come away.
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
I did mine this morning and used q bond with the black powder. Not tried it yet but its set rock hard so I'm hopeful! Will see how this goes Current 2007 TDV8 Vogue Buckingham Blue |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 780 ![]() ![]() |
So it looks like sikaflex does a long term job - I'm pleased I've now got some if/when the JB weld fails.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Watching with interest. Does the 4.4 tdv8 manifolds have this trouble? ______________________________
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Mine was drivers side.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
The 4.4 manifolds and air intake have had 1 revision with Microcat showing them first installed on the first L405. However with all the minor engine improvements in early 2012-built vehicles I suspect that the revised parts may have been introduced at the same time. Maybe one day I'll check mine's air intake to see if I can find anything indicating that it is the revised part. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
I’ve only ever seen UK drivers sides fail... 7 or 8 so far... |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 765 ![]() ![]() ![]() |
Mike Park replaced both of mine last year! And my torque converter |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
I saw a YouTube video of Bondic UV activated sealer/repairer and I thought it might work on cracked inlet manifolds
You may need to leave it to warm up a bit and get someone to rev the engine to see the bubbles. Current 2007 TDV8 Vogue Buckingham Blue |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Where abouts do they crack? Can someone post a photo so I know where to look please. Thanks 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
The split on the top left of the engine block. Remove the plastic cover and it's by the injectors on the left side.
I can’t see on the photo where you are referring to 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
To the left of the two grey plugs is the top of the inlet manifold and it normally splits at the top. Here is a pic of mine when I put the soapy water on to track down the air leak. The angle is from the driver's side of the engine bay so different angle
