|  | Home > Technical (L322) > New L322 owner . Air suspension Woes. |
| nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560    | After battery change you need to reset the suspension. With engine running turn the steering wheel all the way to the left and then all the way to the right - the suspension will reset and the lights go out.
|  8th Aug 2019 10:31pm |
| m666blp Member Since: 08 Aug 2019 Location: cumbria Posts: 10  | Many thanks . | ||
|  9th Aug 2019 9:03am |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Research and find a good local independent LR specialist who are tried and trusted. Search on here and on the sister forums especially the Disco 3/4 one. There is bound to be one or two near you   | ||
|  9th Aug 2019 9:20am |
| m666blp Member Since: 08 Aug 2019 Location: cumbria Posts: 10  | Thanks . There are a couple of good local specialists which I use where necessary. I like to do the majority of the mechanical work myself, unfortunately time pressures etc hinder progress , I’m sure this is the case for most people though.
|  9th Aug 2019 9:55am |
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 548      | Does the compressor run at all?
|  9th Aug 2019 11:38am |
| m666blp Member Since: 08 Aug 2019 Location: cumbria Posts: 10  | The compressor does not appear to work at all . I have reset with lock to lock and still message and no light on suspension switch . Fuse is good .
|  9th Aug 2019 11:54am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | is it right down on the stops
|  9th Aug 2019 12:49pm |
| m666blp Member Since: 08 Aug 2019 Location: cumbria Posts: 10  | Yes , right down on the stops . 2003 tdv6 vogue | ||
|  9th Aug 2019 1:10pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Any orange lights around the height selector ?
|  9th Aug 2019 1:24pm |
| m666blp Member Since: 08 Aug 2019 Location: cumbria Posts: 10  | No lights on suspension switch at all .
|  9th Aug 2019 1:42pm |
| m666blp Member Since: 08 Aug 2019 Location: cumbria Posts: 10  | So I took it took Trojan and they cleared all the faults and away it went again   | ||
|  18th Aug 2019 4:06pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | You need to know what the hard faults are, there could be a problem ? .
|  18th Aug 2019 4:43pm |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | you need your own scan tool RR 2005 4.4 petrol
|  19th Aug 2019 12:56am |
| Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155      | Get a good battery they misbehave badly with current drops | ||
|  19th Aug 2019 6:49am |
| Posting Rules
