Home > Maintenance & Mods (L322) > TD6 gearbox - No drive
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
Hi
Ive bought an 06 TD6 with a gearbox issue from a local guy. Apparently he pulled up outside the house, went into reverse and no gears at all back or forward and had no issues at all before hand.
Ive had broken boxes before that drive but slip, but this doesn't do anything at all. In D or R just revs, no sort of drop in revs like you would expect. P works, N works as in it shift to N and can push it. High and low range works
Fault codes are in the attached picture
Im fully expecting a recon box but is there anything else to try
Can anyone recommend a gearbox specialist that doesn't charge the earth? Local guy is £2200 plus vat but seen others from £1200
Thanks
Post #524493 11th Aug 2019 10:19pm
DrRob
https://www.fullfatrr.com/forum/topic52421.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #524504 12th Aug 2019 7:15am
Weegie
Or?
https://www.fullfatrr.com/forum/topic50798...t=selector
3rd post. John
GAP iiD BT-Sold
Post #524508 12th Aug 2019 8:30am
