Home > Technical (L322) > Front Suspension Bottom Bush Tools |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1446 |
Any recommendations with regard to tools for removing the bushes and installing new ones? Is the a Draper kit or similar that will do the job?
11th Aug 2019 6:29pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
I've got one of these and did the uppers with it but it's much easier with a press as well.
11th Aug 2019 7:18pm |
That looks a pretty good kit, was it man enough for getting the bushes out relatively easy? BMW i3 Electric Car
11th Aug 2019 7:42pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
I had one of those kits and just found the ball bearings got mangled and fell apart after a single use, ended up binning the rods and just using the cups. |
11th Aug 2019 8:42pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1120 |
I went the other way and got the bottom lot from Dan Duckworths under recommendation from my local garage he never changes bush`s worked out a lot easier |
11th Aug 2019 9:31pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
If you are going to change bushes then a press kit like the one in the link is a must. Used on all bushes at the rear of the car ( I mean all - though the inner wishbone bushes needed a big hide hammering as well to get them to move)
11th Aug 2019 10:33pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3517 |
Assuming the ball joint cassette is ok, does anyone know if the front bush could be changed in situ?
11th Aug 2019 10:51pm |
I Did one of my front upper wishbone bushes like this. Depended how corroded in they are in the arms. It's easier off the car but could be done to save the job of removing the ball joint. Current 2007 TDV8 Vogue Buckingham Blue |
12th Aug 2019 7:53pm |
