Home > In Car Electronics (L322) > Audio cutting out briefly
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Lately the audio on my FF has started briefly cutting out. Driving along listening to the radio, there’s an audible “pop” sound, the radio will cut out and the orange light on the volume knob will flash a few times. Then the sound will come back on after maybe 3 or 4 seconds
Noticed that playing CDs it gets a bit confused as well - randomly going back to the start of a track halfway through, occasional dropouts etc
Anyone seen this before? I’m thinking I should pull the amp and check for water ingress. Maybe something else on the MOST bus? 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #524748 14th Aug 2019 9:33am
This might help:
https://www.fullfatrr.com/forum/topic24270.html .
Post #524754 14th Aug 2019 10:41am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
There is a post somewhere about the cables in the rear cubby going behind a metal plate and one of the was rubbing -- it happened to be I bus or K bus, it was enough to throw the system into a complete wobble as data was corrupted -- I'd put money on that or the MOST system Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #524755 14th Aug 2019 10:47am
Tugger
Thanks guys
I’ll have a poke around in the back at the weekend. It’s not a case of freezing entirely, plus I have the newer non-Nokia Bluetooth module so I don’t think it’s that. I’ll keep it mind though.
I did have the battery disconnected recently to install a new brake light switch but didn’t do a hard reset. Is it really just a case of taking the leads off the battery and touching them together? Is there a spark or anything? Batteries scare the crap out of me!
I’ll see if I can see any signs of cable rubbage - that’s a word now - round the back of the metal plates 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #524756 14th Aug 2019 10:55am
Bushy30
You watch out with your use of the word rubbage Rolling with laughter
Yes to the hard reset, let everything sleep, then disconnect, then hold the cables together for a while -- capacitor discharges and all that -- then you should be good to go Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #524758 14th Aug 2019 11:08am
