![]() | Home > Maintenance & Mods (L322) > New windscreen paranoid now |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
Every company has good & bad fitters......
nickt68 Member Since: 05 Nov 2010 Location: Herts Posts: 99 ![]() ![]() |
I’ve recently had them change a windscreen on my weekend car, but hopefully Alistair is right.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 252 ![]() ![]() |
National did the screen on my d3, used a generic one and it worked a treat.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Call them tomorrow and insist on a genuine one and an experienced fitter and confirm if new trims and fixings etc come with it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
yeah i will, i tried tonight but could only get through to a call center the lady said they would use like for like but that's kind of open to interpretation i guess..
https://www.fullfatrr.com/forum/topic36415...p;start=15
John61 Member Since: 20 Jul 2018 Location: East Sussex Posts: 147 ![]() ![]() ![]() |
Had a bad experience with Autoglass which may be worth taking into account, i would recommend asking for a master technician even if that just means an experienced fitter and more importantly that there is an assistant because the size makes fitting easier. The first attempt with one guy ended in it being fitted incorrectly and was getting damp in the car. Also check they have all the fittings for the a pillar trim which differ from model to model.That caused an abhorted fitting. You are right to be paranoid, replacement will need managing. John Holland and Holland Range Rover By Overfinch |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Once fitted (properly) you will become even more paranoid about that first stone chip!
Well called National this morning and the guy at the depo said he can order me a proper pilkington price of glass so I guess that’s good.
Also insist that someone experienced is booked to fit it even if it means taking it their depot.
I asked how many people were doing it he said 2.
Well I guess I was right to be paranoid.
Switch the heated screen on and hold your palm onto the outside of the windscreen. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
