Home > Technical (L322) > Rear Heated Seats 2010 MY Vogue |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 154 |
Hi All
12th Aug 2019 12:18pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1127 |
Do you rotate the knob first then press the switch? |
12th Aug 2019 4:25pm |
Hi tinman
14th Aug 2019 9:32am |
Thanks nickt68 for the reply, I had checked the connectors under the seats awhile back and more recently and they are both plugged in, when the lights were working the other day I noticed that the single light on the button would flash when you disconnected the plug under the seat which seemed strange.
14th Aug 2019 2:57pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
IIDTool?
14th Aug 2019 3:01pm |
Hi
14th Aug 2019 3:51pm |
Low and behold last week I stopped the car and the gear selector panel lit up, it’s never don’t that since I got the car. I checked the rear seat heaters and both switches lit up and the seats heated up perfectly. The gear selector panel and seats worked all day and then the next day stopped working again. Anyone had this problem and managed to sort out, I’m thinking it’s got to be a bad earth. |
29th May 2021 5:14pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
I'm guessing it's a dirty multi plug somewhere in the rear of the centre console, maybe upset by a previous owner spilling drink down there...! Pete
29th May 2021 5:50pm |
Thanks for that Pete, I did awhile back strip down the centre console and clean all the multi plugs. As I have a rare week off work coming up I may try that again. |
29th May 2021 6:29pm |
Just to update on an old post for the last few days when I have got in the car and started it up the PRND has lit up ie red when in Park then orange when in the other positions are selected and the the rear heated seats works ( I know the gear selector lights and rear seats share a fuse so makes sense they both work at the same time. The map lights also work when this happens but not sure they share the same wiring but guessing they do, everything works for a few minutes and goes back off. Seems very strange, obviously a earth problem as the fuse must be ok. Anyone know why they would work at start up and then go back off after a minute or so ? |
6th Jul 2022 5:58pm |
