Home > Maintenance & Mods (L322) > Viscous coupling pulley retaining tool 303-1241 ?
leusfx
Hello,
I need to source Viscous coupling pulley retaining tool 303-1241 according to workshop manual.
Could any one help? There is no such thing on the web.
Post #524964 15th Aug 2019 5:53pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I got mine from here (assuming that's what you are after):
https://www.powerfuluk.com/catalogsearch/result?q=viscous
Post #524984 15th Aug 2019 7:56pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I just used a thin chisel between the bolt heads, but you could probably use a piece of 15mm wide steel. Key thing is at least 3 or 4 hands to hold the pulley "blocker" and the viscous fan tool + hammer.
NB make sure you don't hit a fan blade - they break or split! Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #524985 15th Aug 2019 8:05pm
leusfx
In order to remove Cooling Fan the Work Shop manual for TDV8 2006-2010 says that I need Special Tools.
1] Viscous coupling spanner 303-1142
2] Viscous coupling pulley retaining tool 303-1241
Powerful uk replied that they don't stock this item and so it may be worth checking on the Range Rover forums for alternative stockists in this case. I think they just sell 303 -1143 alternative which is for Disco 3 a 4.
The Viscous coupling spanner 303-1142 is available on ebay/amazon no issues there.
But Viscous coupling pulley retaining tool 303-1241 is i bit a mystery for me. Is it just some kind of wrench? Any alternative, please?
Post #525011 15th Aug 2019 10:32pm
Pawl
The Viscous coupling pulley retaining tool 303-1241 is just a device to hold the pulley stationary while you use the fan nut spanner to loosen the big 36mm nut.
All it does is locate on 2 or 3 of the pulley retaining bolt heads - for you to then hold the tool or abut it against something that won't move.
Land Rover would probably specify a special tool to ensure minimal chance of their "skilled" mechanic making a mistake - even though any real mechanic would know what they're doing. Paul,
Post #525021 15th Aug 2019 11:40pm
gavinn
I always use a "heel bar" , pointed end on the nut and a good whack with a 4lb hammer , keep the bar as vertical as you can and 3/4 the way across the nut (to the right hand side when looking down at it standing in front of the vehicle), will give you a better turning moment of torque, normally shocks them off with no problem , remember its a left hand thread !
Post #525034 16th Aug 2019 10:34am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
thats mine
works fine RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #525054 16th Aug 2019 2:00pm
nino_nino
and mine
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #525072 16th Aug 2019 4:35pm
leusfx
That's nice collection of tools. Thank you all very much to make it clear!
Just found this on my phone:
[/img]
Post #525099 16th Aug 2019 10:03pm
knares
i never undid the four bolts RR 2005 4.4 petrol
Post #525122 17th Aug 2019 11:15am
nino_nino
remove 4 bolts only if you intend to change fluid inside viscous coupling. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #525124 17th Aug 2019 11:37am
leusfx
Eventually, I ordered Part No. LRT146-2PC from powerfuluk.com (Retaining tool and the 36mm Spanner) and it worked like a charm. The tool is also compatible with FFRR TDV8 engine and fits on the pump. Thanks everyone.
Post #528331 17th Sep 2019 4:11pm
