Home > Maintenance & Mods (L405) > Landrover main Dealership response to a steering Issue
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
2016 L405 vogue se sdv8
Had my car in for some warranty work recently and asked them while it was in to check the steering geometry as the car pulls slightly and can sometimes be very “vague” in a straight line
Answer I got was “ head technician has had the car out on a test drive and can not fault the steering ) so no need to carry out a full 4 wheel alignment
Just had a Hunter 4 wheel alignment done from an independent specialist I’ve used in the past and can trust to do the job right
Below is the outcome
Are the dealerships really that bad ???
The car does not “pull” now and 100% better in a straight line Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #525146 17th Aug 2019 4:08pm
DrRob
If the main dealer had done the same they would have seen the results not just a test drive assessment. Another example of why I avoid them like the plague 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #525147 17th Aug 2019 4:14pm
DrRob
I'd send the main dealer a snotty letter and the invoice 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #525148 17th Aug 2019 4:15pm
