![]() | Home > Maintenance & Mods (L322) > Electronic Handbrake cable snapped... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Yes you have to drop the subframe to provide access and enough space to remove the EPB module. You will also need to use iiDTool or similar to "set" the EPB module.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Well that stinks - when you say set is it to clear the faults ? I have a snapon tool would that be ok? Is it worth just getting an entire new epb module or am I talking big bucks? Current stable:
Read the F manual, it is explained there |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
When my 2007 EPB packed up i sourced a secindhand ine from the Ukraine and had it serviced before fitting. My old one had a burnt out motor which would have been an easy fix but I didn't want to have to much down time because it is a big job. 2015 4.4 AB
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I've just had to have my EPB module replaced as it failed the MOT on one side of the park brake not working, Apparently some of the gears were stripped in the EPB.
