Home > Off Topic > Replacing my knackered pressure washer
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
My elderly baby Karcher 80 went bang the other day just as I was preparing to clean the weekend's mud off my Defender. Does anybody have a recommendation for something to replace it with - this time I would like something that can steam/hot clean as well as pressure wash. Not too worried about huge pressure as with my Def that is likely to also remove paint and I'm not yet ready for a polished Aluminium Defender................ 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #52534 2nd Mar 2011 2:20pm
loads on machine mart from about £800 upwards... ... - .- -.
Post #52539 2nd Mar 2011 2:30pm
What you have to remember with hot pressure washers is the amount of power they take to operate. A household socket can handle 13 amps and you can go up to 16 without too much worry, but when you start going higher than that you can run into problems and this is the reason most heated PWs are 3 phase.
Kranzle are about the best there is on the market today but they are expensive.
I have a couple which I could recommend, the Lavor Ontario which is a large, high output cold water machine for commercial use which I have owned for 6 years now and it really does shift dirt, caution required on an aluminium Defender. I recently bought a Nilfisk C120 which was mega cheap, about £70 on promotion and these have a massive following on the detailing forums. The Nilfisk is perfect for cleaning cars but would be a complete waste of time for pressure washing paths, patios etc.
Don't waste money on a petrol driven PW, they really aren't very good and try and keep away from Karcher, they were good years ago but they now have plastic pumps and reliability is not very good.
For long life you want to get one with a motor speed of around 1400rpm, but again these are usually on the larger machines.
If you need any further pointers let me know.
edit
Just checking the Machine Mart site, don't touch anything Clarke.....utter rubbish
Post #52546 2nd Mar 2011 2:47pm
Paulo
I agree with Alan, I too have a Nilfisk C120 which replaced a Karcher, great bit of kit for the money.... Thumbs Up
Post #52551 2nd Mar 2011 3:31pm
Alan Big Cry Laughing Laughing Laughing
Post #52567 2nd Mar 2011 3:58pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
i use a Karcher K7.85M
will take hot water 'off the tap' up to 60 degrees C
had a hot water tap fitted specifically fitted
Post #52568 2nd Mar 2011 3:59pm
mrjamescollins
United Kingdom 2005 Range Rover Vogue Td6 Java Black
another vote for the Kranzle here.
Post #52577 2nd Mar 2011 4:33pm
Paulo
Ooopsss.... Exclamation
My memory for names is legendary.... Embarassed
Sorry.... Bow down
Post #52578 2nd Mar 2011 4:47pm
Sorry.... Bow down
No problem Billy Thumbs Up
Post #52581 2nd Mar 2011 4:54pm
mzplcg
Check out the Nixon range. Big and very farmer-ish. Based on Kranzle fittings and easily replaceable pumps etc. Proper pumps which have the ability to change oil etc. Diesel or kerosene fired boiler for hot wash and variable pressure at the nozzle (adjusted on the main pump valve)
Indestructible if looked after. Had mine for 6 years now. Serviced once a year by a mobile guy and even survived the frosts over winter when I forgot to drain it properly.
Downside is it's not exactly portable. Wheels to move around but too heavy to lift into the back of the RR.
Link here.
http://www.briannixonjetters.com/pressurew...aster.html
Post #52593 2nd Mar 2011 7:47pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
I use the hi end domestic Nilfisk Alto its about £320 but being a domestic come with 3 year warranty, has foam lance and own pick up unit and you can run up 80" water through it ( i never bother ) snow foam and cold water is fine. Far to many gone...
Post #52603 2nd Mar 2011 9:36pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
CPC do a good line of Nilfisk:
http://cpc.farnell.com/jsp/search/browse.j...%2B1001276
And I can get a decent snow foam lance for about £50, with some foam, as well as other detailing bits. Thumbs Up
Post #52610 2nd Mar 2011 10:12pm
Paulo
A neighbour has had one of these for a while, which he highly recommends....
http://www.lidl.co.uk/cps/rde/xchg/lidl_uk/hs.xsl/index_18814.htm
Looks like a steal at the price with a 3 Year Warranty too, if only I could bring myself to enter their store... Wink
Post #52702 3rd Mar 2011 4:03pm
Sidney
Wales 2005 Range Rover Vogue Td6 Cairns Blue
We have got through loads of K'archers, will never buy another. Years ago they were well built industrial strength tools, alas no more.
As said before Kranzle are excellent, its what we use now, and some very compact. Interpump good too aparently. Dirt driver are the nuts, expensive though.
Post #55923 22nd Mar 2011 1:26am
