Home > Technical (L322) > Reduced Performance (Limp Mode) No Fault Code |
headless21 Member Since: 28 Jun 2016 Location: Yorkshire Posts: 23 |
Hi everyone, I have a L322 2011 4.4 TDV8 and it randomly keeps going into Reduced Performance (Limp Mode) but does not show any faults (I am using Gap iid tool). It can do it when accelerating slowly or hard, mostly does it when going up long gradient and lightly accelerating. If i press clear all faults on Gap tool it gets rid of the Reduced Performance message and then the car runs perfectly. I did a trip of about 100 miles and it went into Limp Mode 12 times. Can anyone give me any suggestions where to start diagnosis. I have checked all hoses for splits. My car seems to have 2 air sensors one in each air box but I can only see 1 Mass air flow on Gap tool, could these trigger limp mode and not show a fault code.
19th Aug 2019 7:36pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
If teh MAF wiring goes open or short it would then show an error, if the reading were incorrect it wouldnt. I had similar problems when I first got the GAP tool, light on but no errors, there is a setting somewhere to show all errors not just ones that have happened 'x' times. Im away at the minute so cant check, have a look around in the GAP software the next time you have the fault. BMW i3 Electric Car
19th Aug 2019 8:30pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Symptoms match split hoses.
19th Aug 2019 9:11pm |
Thanks guys for the quick responses, you have given me a few things to check, I really appreciate your help. 👍 Current Range Rover Vogue SE 2011 4.4 TDV8
19th Aug 2019 9:19pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3677 |
Next favourite on the list after split hoses would. be a split in the plastic plenum chamber., usually at one of the seams.
20th Aug 2019 7:54am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
The original secondary turbo inlet isolation valve on 4.4's built before late 2011 is prone to sticking. It is high on the list of suspect causes after the 4 short air intake to manifold hoses. However these failures trigger fault codes so is your IIDTool correctly configured to read all fault codes? |
20th Aug 2019 10:41am |
Mine had a stuck valve replaced because of the restricted performance alarm, but it did raise a fault code to help locate the problem. G reg 2.5VM Vogue Portofino red 1991- 1999
20th Aug 2019 11:05am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
Martin
20th Aug 2019 11:51am |
