Home > Maintenance & Mods (L405) > LED door puddle lights
supershuttle
WOW Shocked makes my 50p look good value Whistle Rolling with laughter Geoff
Post #525970 23rd Aug 2019 9:26pm
Ukandrewf
well all installed.
front door (right) with LED and back (left) without.
LED on on the right is clearly brighter.
both done
and a close up on the front door which shows some dots in the colour? or is it just my eyes being burn from installing at night without a good torch.
nb.
a) the flat screwdriver slides in from the side and stays horizontal to prise out.
b) first two installed ok but passenger front door new bulb kept coming back out (didn't lock - had visions of the hassle to return it), put the second bulb in and it worked fine, took the previous bulb and put in the back passenger door and now it worked fine. So if a bulb doesn't lock in one door try another.
c) perhaps i should have chosen blue ...
Andrew --
On my third Full Fat RR
Post #526288 27th Aug 2019 9:12pm
supershuttle
Mine seem to have stopped working, there is also a bit of confusion in my mind about what constitutes a "puddle light" the one from the mirror which projects a Range Rover logo on the floor isn't a "puddle light" (it still works anyway) but the ones that have packed up are the ones under the doors, which illuminate where you put your feet when the door is open and you are alighting so you don't step in puddles. They were working fine after I changed to LED (in fact I was very pleased) but since doing the footwell lights which change colour (also pleased) they have packed up - probably coincidence or perhaps I have only just noticed. I'll investigate as soon as I get chance - anybody had similar? Geoff
Post #574370 28th Nov 2020 12:27am
