Home > In Car Electronics (L322) > Nokia BT module
texaspete
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
Nokia BT module
Hi all
Just picked up a 2005 Full Fat. The Bluetooth module was missing but wiring was there. Reading the service history, it had been removed due to being diagnosed as faulty. Fibres had a loop cap fitted.
I've got a replacement and plugged it in but just get the start up screen and flashing orange light.
Got red lights through the fibre.
Is there any way of checking to see if I have brought a faulty Nokia BT module before I return it?
Oh and can I replace the tuner module with a hybrid without any issues? Seen a couple fairly cheap.
Thanks all.
Post #505987 22nd Feb 2019 7:59am
texaspete
Follow up
Go at it all sorted.
The Nokia BT module I purchased was the upgraded one. The plug didn't fit properly and I was trying to plug it in up side down..
I removed the lever and it plugged straight in. Works perfect.
Post #506271 25th Feb 2019 8:13am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #506283 25th Feb 2019 10:49am
Danwilderspin
Hi pete - updated one from a 2010+? Did it work on yours ok? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #518281 13th Jun 2019 8:24am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Yes use a 2010 FF module or a Disco 4 module, there is a handy guide to doing this on Disco3.co.uk that may have been cross posted on here by Wiggs.
Post #518358 13th Jun 2019 5:49pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Have just done the ‘Wiggs’ bluetooth module upgrade described in the Wiki. Took minutes and works a treat. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #522441 22nd Jul 2019 7:19am
Danwilderspin
Will one off a l320 sport 2011 do the job? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #522443 22nd Jul 2019 8:12am
Jamiehol
Should as the system is the same as a Disco and similar age L322.
Post #522489 22nd Jul 2019 5:33pm
Danwilderspin
Hi right just started looking at this - which two colour wires do you use from the original connector? On the wiggs post it’s a red one and a black one which don’t appear to exist? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #525598 20th Aug 2019 9:54pm
elblanco
Ireland 2007 Range Rover Vogue SE TDV8 Santorini Black
I'm researching doing this now too, I think that doc shows you 2 cables that you need to get yourself to bridge the gap between new bluetooth adaptor and old harness.
Post #526141 26th Aug 2019 11:18am
Danwilderspin
I found the info out from disco forum it’s a piece of cake I took the two pins out wrapped in electrical tape and used a hot glue gun to lock them in the new connector all works great.
Positive pin 16 negative with 33/34
The hardest thing is mounting it it’s balanced and gently cable tied currently. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526211 27th Aug 2019 9:10am
elblanco
Nice one @Danwilderspin I'm going to purchase a new bluetooth module today and attempt it as soon as it arrives. Do you mind if I ask what model did you order and what did you pay for it?
Also, does this resolve the issue of having to pair your BT device every time you start up the car?
thanks!
Post #526215 27th Aug 2019 9:23am
Danwilderspin
8H22 10F845 AA. paid £50 eBay...
cheers! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526227 27th Aug 2019 11:57am
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Worth noting if you have an IID tool . It has a BT upgrade available as std - worked on my 2006 4.2 - pairs immediately , phone book etc P525
4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #526238 27th Aug 2019 2:22pm
elblanco
thanks, ordered!
Post #526243 27th Aug 2019 2:51pm
