![]() | Home > Maintenance & Mods (L322) > Any other known rust spots? |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Rear hatch, along the bottom edge mainly but have seen them bubble up in other areas.
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 336 ![]() ![]() ![]() |
Would recommend POR15 over smoothrite , if applied as per directions it’s amazing stuff
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Interesting. Never heard of it. Too late now though, I've already bought my stocks! Thanks! |
Yeah, I figured I'd wash/rub down and paint anything I could get access to. Should keep the tinworm at bay and help maintain value as the years go by. Thanks. |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
The LH wheel arch rust seem to start from the inside, from below the entertainment system. Won't do much good to do preventive work on the outside if that's the case.
I know where you mean about the arches from the inside out. I did however manage to get a lot of waxoyl into that area with a probe. You can reach it through the holes that the pop studs for the plastics go into. I suspect a lot of the sill areas can be done in The same way as there are pop studs all along the length of them for the plastic oversills. I’m even tempted to drill small holes to get the wax in the sills and then plug them with grommets. If you get a professional wax treatment done they will do that anyway. You just have to paint the holes too and make sure they are not a rust trap in themselves. |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 432 ![]() ![]() ![]() |
Are people also protecting the subframes?
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1422 ![]() ![]() ![]() |
In addition to the above, the brake lines are prone to rusting,mine were waxoyled every service after about year three, as advisory on MOT by then (2012 WM, admittedly used off road and lots of salt on roads in Scottish Borders). Only Range Rovers since 1988 |
I plan to do all I can reach. It’s really in great shape at the moment so I plan to try and keep it that way. |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I've just had to have the whole lot replaced. Really not impressed that they've rusted through in such a short time. 2010 4.4 TDV8 Vogue SE |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Replace with Kuniform/Cuniform, no more rot EVER! 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Apologies Kunifer... |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 613 ![]() ![]() ![]() |
was behind a 56 plate today boot lid rust holes all the way through |
