![]() | Home > Technical (L322) > 4.4 TDV8 Auxiliary Belt |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
The manual is now available if you look in the Wiki.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3334 ![]() ![]() ![]() |
Thanks Mike,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
my tdv8 chirped for the 3 winters i had it ...the noise didnt last long and i just ignored it.... ... - .- -.
This one does it every time it's cold and it lasts for 5 minutes or so until it's warmed up. It's not bad, it's just irritating when you get out of it whilst it's still cold and running. |
5 hours labour sounds a reasonable quote to me, plus they will have the special tools required.
It isn't a bad quote at all. Some jobs I quite enjoy doing myself and I'm just wondering if this is one of them |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Or a can of Carplan Beltup which is what i use on the L200 which always has a chirpy belt. Have to reapply it every now and again. It lubricates the belt as they can dry out a bit. Current Fleet:-
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 57 ![]() ![]() ![]() |
Just had mine done by an Indy in Littlehampton, it was noisy for about 2-3 min. Apparently there is a modified alternator bracket which resolves the core issue think he said there is tsb referencing it. Cost roughly £875 to rep idlers, bracket tensioner & belts - gen parts
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Which indy in littlehampton? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Charnocks automotive,Riverside ind est, Littlehampton |
