Home > Maintenance & Mods (L322) > 4.4 TDV8 transfer box fluid
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Hi
Can anyone tell me what I need and how much to do a change please? The owners handbook gives me a code that I cannot find in google.
Thanks
Post #526622 31st Aug 2019 8:46am
Rambles
I found using the search that I probably need 1.5 litres.
And that the transfer case oil is basically 75-90w gear oil.
Which is the Castrol SAF XO
If I put the XO into my transfer case, would it be ok?
Or do I need the carbon mod plus (bot no. whatever) because the transfer case has some electronics in it?
Post #526662 31st Aug 2019 4:29pm
pld118
https://www.fullfatrr.com/forum/topic50586...t=transfer
Post #526671 31st Aug 2019 6:20pm
nino_nino
Rambles,
do not use 75-80 oil for the Transfer case. it is oil for differentials. use land rover special TF oil or Ravenol TF 807, cheaper
https://www.ravenol-direct.uk/ravenol-transfer-fluid-tf-0870.html
https://www.amazon.com/Ravenol-J1C1125-Tra...B00QCVP6UK 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #526672 31st Aug 2019 6:34pm
DrRob
https://www.advancedfactors.co.uk/service-...-168-c.asp
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526673 31st Aug 2019 6:38pm
