![]() | Home > In Car Electronics (L322) > 10" Android head unit. |
tveitan Member Since: 10 Dec 2016 Location: Norway Posts: 47 ![]() ![]() ![]() |
Hi everyone,
And here's a cheaper alternative for the 2002-2004 models. I guess it should fit even If it doesn't say specifically..
And here is a picture showing how it looks. Think I might give it a try...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35758 ![]() ![]() |
looks ok |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8055 ![]() ![]() ![]() |
As above - For the first one, whilst it shows compatibility for all L322's, there is a significant difference between pre 2006 & post 2006 when pretty much everything changed from BMW to Ford electronics.
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
$1k plus import tax for an android 5.1 unit seems a bit much for an old unit of a no-name brand, especially one they list as being for 2002 - 2012.
I agree. Doubt it works for all model years. Could be that it works with the most system.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
I think any will work with an 06+ as there is still a very small ibus system up until 2010 (steering controls and clock) so you would be ok there, you need a most converter £100 not too bad but the show stopper for me is losing the RSE if anyone can come up with a solution to this or it be able to be used Independently I’m all ears Current stable:
michu Member Since: 12 Nov 2019 Location: Sevenoaks Posts: 7 ![]() ![]() ![]() |
It looks like this one that I have found a few days ago on Aliexpress right from the manufacturer: https://www.aliexpress.com/item/33030950516.html
Funny you posted that - I bit the bullet on this yesterday as my last remaining rse screen has died.
I just ordered a similar one as well with carplay, DAB and a DVR camera with something they call ADAS, which is supposed to give you lane departure warning and front collision warning. My expectations for the ADAS are quite low to put it mildly, but will be fun to see |
I went for all of that except the ADAS as I thought it would be a load of arse |
You're probably right about ADAS |
I’ve done it in my 02 ... twice...
