Home > Technical (L322) > Servotronic / BMC / Annoying issue |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 667 |
Sounds almost like the steering pump pressure relief valve is doing something odd.
31st Aug 2019 8:19pm |
griffc Member Since: 06 Jul 2019 Location: UK Posts: 10 |
Only ever starts playing up when going over 55. Keep the car below that and it’s perfect. |
31st Aug 2019 9:22pm |
It certainly won't be Servotronic valve related. The servotronic adds max additional assistance at zero speed & then progressively reduces that extra assistance as the speed increases. From memory when testing mine, it's still doing something - although minor - at 70 mph.
31st Aug 2019 9:39pm |
Hi. At 70 you can just hear a pulsing / hammering noise. As you slow down to around 50 you get steering shake. Braking to a halt you get violent shake and you can feel it through the pedal too. When the problem doesn’t show then all is fine. It’s a td6 03 with 110k - it does tend to hover around 3k whilst accelerating so might be flakey torque converter but I wouldn’t expect the steering shake.
31st Aug 2019 10:06pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
I had a very similar problem a few months back and the problem was the bolt on the front offside lower control arm was loose (this was after it had been into a local garage to replace the driveshaft boot - they hadn't tightened the bolt up properly - it was just hand tight).
31st Aug 2019 10:39pm |
Front end has all just been done and the problem is intermittent so I think everything should still be tight - I will check though.
1st Sep 2019 10:14am |
I drove mine with the servotronic disconnected for weeks when trying to identify my steering problems.
1st Sep 2019 10:28am |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 79 |
I had a very similar issue with a judder at 55mph;. Mine is a 2011 L322 4.4 TDV8 - turned out to be the front diff. Replaced it and judder gone. I still have heavy steering above 5mph...replaced steering rack and pump....still the same...can’t find my BCM as it’s not under the passenger seat on my car.... it’s on the list to fix |
1st Sep 2019 2:46pm |
This ended up being a combination of things. The servotronic fixed the 55mph issue and binding rear caliper fixing the rest - hurrah!
6th Jul 2020 7:28am |
